Old 05-05-2013, 03:37 PM   #15
Skootnasty
Did the shop you had the car at remove the cam covers, lifter cradles, and lifters? If you do this and clean the oil away, you will be see the crack at the valves for either cyl #1 or #6.
A cracked cylinder would also have a misfire, so again you have a cracked head.
Skoot
Skootnasty is offline   Reply With Quote
