Old 05-04-2013, 10:54 AM   #11
Johnny Danger
Johnny Danger's Avatar
Originally Posted by jaykay View Post
I believe that there are no 10s for the Boxster only 9s.
Thanks Tom for your input. So the limit will be the spec Boxster set up.
I am I correct in thinking that corner balancing will not be accomplished without adjustable drop links and roll bars that can accept them?
Edit looks like JD asked the question already.
JK,
In the absence of adjustable drop links, I think what most knowledgeable race prep guys will do, is adjust the ride height (turns on the perch) to accommodate what changes in ride height will occur when the driver is seated. This as you probably know, is accomplished put simulating your weight during the set-up. While it's not optimal, is probably sufficient for street set-up. That's what was done in the case of my vehicle. I'd like to hear Tom's input on this though.
