Old 05-04-2013, 05:05 AM   #2
Homeboy981
Homeboy981
Homeboy981's Avatar
36psi ALL the way AROUND? Isn't it supposed to be 29 in the fronts? …unless you "squared" your setup on all the same rims and tires.
Again, that is for COLD tires pressure AND regular driving. If you are going on the track or going to drive more aggressively adjust the pressure DOWN - as the tires will heat up alot more more at high speed. Don't know pressures for AX, sorry.
I am getting at least TWICE the mileage out of my fronts and I am in the rear. In fact, I am on my 3rd set for the rear, while the fronts look fine.
