Thread: Thanks
Old 01-10-2006, 05:34 AM   #2
donv
donv's Avatar
Originally Posted by 70Sixter
I did the same thing. First I let the oil drain bolt fall into my oil catch tray. Naturally it worked its way into the oil opening.
Yes, had the same problem. Now I have a piece of hardware cloth (1/2" square opening screen) over the drain hole when I do an oil change. Don't have to panic and fish out the drain plug from the hot oil to prevent an Exxon Valdiz moment!
Originally Posted by Adam
The easiest way to change the oil is use a floor jack and lift up the left side in front or the rear wheel. Get under there and do your biz and let the car back down so it is level. Once drained, lift back up replace filter and plug and add oil. Just make sure you have a big container! 9+ quarts of oil is alot! Super easy that way and no pesky ramps.
Please oh please remember the jack stand(s) if you do it this way. Flattened Boxster enthusiasts are far less fun.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
