Old 05-01-2013, 08:36 AM   #10
southernstar
986 inquiry, lower gear ratios are not necessarily better even for 'peformance' driving. I assume we can agree that what is critical is matching the gear ratios to the engine. The 2.5 had less torque, expecially low in the RPM range and hence needed lower gearing. What is more, your analysis fails to take into consideration the fact that the 2.7 and 3.2 had higher redlines - an increase from 6800 rpms to 7200, or roughly 6%. I am quite confident that Porsche, in attempting to improve performance over the 2.5, came up with what they believed were the best ratios to achieve this with the upgraded engines.
Brad
southernstar is offline   Reply With Quote
