Old 05-01-2013, 09:22 AM   #10
986_inquiry
2006 987
986_inquiry's Avatar
seems I'm right, the 2.5 had the best gearing while the 2.7 has the worse
Originally Posted by insite View Post
actually, they're not. you have to consider the final drive. the 6-speed FD is 3.44. the 2.5L is 3.889 and the 2.7L is 3.555. you need to multiply each geary by this number to get an EFFECTIVE gear ratio.
the truth is, the 2.5L has is geared lower than either of the others by a pretty substantial amount. the 2.7L, IMO, is the LEAST desirable. next is the 6-speed. the 2.5L 5-speed has the most useful ratios from a performance perspective.
2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
986_inquiry is offline   Reply With Quote
