Old 04-30-2013, 01:07 PM   #5
Burg Boxster
x2 on clutch interlock switch. As stated above, it's cheap and easy to replace.
Until you replace if it happens again, just loosen plug on the back side and run a jumper wire between the contacts but MAKE SURE IT'S OUT OF GEAR BEFORE TRYING TO START or clutch is pushed in.
Good luck
