Old 04-29-2013, 10:29 AM   #4
ccstud17
ccstud17's Avatar
Sam hate to hear you are back in this position....
check your rear drain to see if it is clogged, easing a wire hangar all the way thru the drain is what I had to do to fix mine. also maybe replace the fuse, like .15 cents to rule out any issue there, emery paper the fuse receptacle...
really hope it is something easy like this and you can get back into driving her!
Stop lights timed for 30 MPH, are also timed for 60 and 90 MPH!
ccstud17 is offline   Reply With Quote
