Old 04-28-2013, 06:32 PM   #14
bmx672
Originally Posted by wawa View Post
PCV valve, I would say as hard as the AOS the first time. Its just so tight in there. Hardest part I think was reconnecting the hose to the PCV valve.
later
Chris
Is it easier with the manifold removed? I did the AOS with it on before, but if it makes it easier to change both by taking off the manifold ill probably do that... Not sure if that's even a good idea?
Thanks for the input...
bmx672 is offline   Reply With Quote
