Old 04-28-2013, 03:03 PM   #125
986_inquiry
2006 987
986_inquiry's Avatar
Originally Posted by southernstar View Post
In addition, the upgraded IMS bearings that are now available (and which can be installed for very little additional labour costs over a clutch replacement) should all but eliminate this as a cause for concern for purchasers who see these as collectible cars, rather than daily drivers.
Brad
I do need to point out that their are two "upgrades" to the IMS: the "IMS Retrofit" and "IMS Solution".
IMS Retrofit | The LN Engineering IMS Retrofit Kit for MY97-05 Porsche Boxster and 911 Models
The IMS Retrofit is an upgrade but not a fix, IMS can still occur but is much less likely. Current price for the part is $650. Porsche essentially installed this in 2006+ 987/997.
IMS Solution does away with the bearings that would fail. It's currently $1,500
Then there is the IMS Guardian which is basically a magnet on a sensor that warns you if there are metal shavings in the oil. That's currently $260-$410.
IMHO every 1997-2008 porsche owner should have at least a Guardian. I will be having one installed come next oil change, since the sensor replaced the oil plug it's best to install when oil is drained. Even with a 2006 I worry, and IMS failure is not the only reason metal may be in the oil.
2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
986_inquiry is offline   Reply With Quote
