I just changed my AOS less than 10k miles ago and its blowing oil again into the manifold again... i'm thinking the PVC valve might be the reason?
Question... if a bad PVC is the reason my AOS is blowing oil and I fix the PVC, do I need to also replace the AOS again? Or will that operate normal once the PVC/vac problem subsides?
