Old 04-26-2013, 08:40 PM   #3
3.2S
If it's leaking between the engine and trans you have a front pump seal, pump o-ring or pump bolt seals. Output shafts leak differential oil not trans fluid. Outside trans oil cooler lines are on top on tranny down to the left side.
3.2S is offline   Reply With Quote
