Old 04-26-2013, 08:49 AM   #14
CoBeerToad
CoBeerToad's Avatar
Finally got that stupid triple square bolt!
Ended up using a hex bit (I guess that is what you would call it). About 3 inches long. I put a 7/16" box end around it and jammed the bit in the bolt. Then I took a large broken screwdriver and put that between the bit and the final drive and hammered it in there wedging the bit in the bolt so it could not slide out and strip it. I had enough room on the front side to rotate the box end wrench.
Probably wasn't the "correct" way, but after taking this long and my level of aggravation, I didn't care anymore. Heading to the hardware store to find a replacement bolt as there is no way I am putting that stupid bolt back in there.
I think that should add at least $500 to the value of the car also!
CoBeerToad is offline   Reply With Quote
