Old 04-25-2013, 07:33 AM   #2
jaykay
jaykay's Avatar
Sounds good. Why did you choose this particular pump? What is the output with respect to the stocker? It's probably much more stable and will give the ps control valve less work.... but output pressure range?
It would be really handy if the ps control valve was right in the frunk somewhere....are you drilling to get to it??? Perhaps it's modularized with the rack....bummer
Are you removing all the ps lines from the back?
Will the gutted ps pump require some fluid to keep its bearings cool and lubed while idling? Will you still have to service this fluid?
986 00S
