When I changed my water pump last year, it had orange extended life antifreeze in it.
After flushing out the system I refilled with Porsche OEM coolant.
Some people use OEM antifreeze, some use regular brands. Your car, your wallet, your choice.
Most will agree that you should not mix OEM with aftermarket brands, so make sure you flush it all out before refilling.
Replace Water Pump
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
