Old 01-08-2006, 03:18 PM   #14
porschephd
Having a CARB number and actually having clean enough numbers are not one in the same. CARB is a mountain of paperwork, expense and testing to ensure that the state of CA is happy on all levels. Because a product is not CARB certified does not mean that if one was to go to a testing station it wouldn’t pass. From a emissions level standpoint it will pass on the idle and on the rolling (dyno) test. All readiness status checks read ok and the levels are within state passing levels. So in long the answer to your question is you would pass
porschephd is offline   Reply With Quote
