Originally Posted by Dr.Strangepork
Fantastic thread. What are the rules in GT class? Does the car just have to fall within a certain power to weight range and you can do whatever else you want to it?
Thanks. Very few rules in the GT class so we can pretty much do what we want.
We have 3 types of tire to choose from: Slicks, DOT <100TW, and DOT>100TW
Cars with slicks must run the most weight, less for <100TW, then even less for >100TW. I've chosen slicks, as does most everyone in the higher classes because the DOT's overheat on the higher HP/higher grip cars. We also have a great contingency program with Yokohama, which is why I have so many of their stickers on my car. Last race weekend, I won a full set of 4 valued at around $2k for my class wins.
Class with Slicks
GT1 less than 7.01 lbs/hp
GT2 7.01-9 lbs/hp
GT3 9.01-11.5 lbs/hp ** I ran 316rwhp and 2850lbs last race (restricted hp and added ballast)
GT4 11.51-14 lbs/hp
GT5 14.01-16.5 lbs/hp
GT6 above 16.5 lbs/hp
Weight is including driver and fuel and you must meet weight at any time during qualifying or the race. We always get weighed in after the race (top 3 finishers).
Only rules are:
-Car are limited to one wing (no front wings attached to the hood). Wings must be single element (no multi element wings). No active or in car adjustable aerodynamic devices.
-All engine swaps must be of the same manufacture.
-all tube frame cars must take the slick weight requirements
-maximum of 350lbs of ballast
-switchable ECU's must be declared, inspected, and explained
