Old 04-23-2013, 07:41 PM   #1
3.2S
Most likely it's the front pump seal where the torque converter plugs into the trans. There is also a o-ring around the front pump that could leak or the bolts that hold the pump in.. The torque converter seal and bolt seals can be replaced easily once the trans is removed but the o-ring is much more involved. Good luck.
3.2S is offline   Reply With Quote
