Old 04-21-2013, 06:00 PM   #1
jetrocker
Power Drivers seat - Switch weirdness
Hi all
I had my 2000 seats recovered by a pro shop and put them back in today. Pass side, no sweat. The drivers side however, now has all kind of issues with the control switches on the side. The horizontal one (fwd) will not move the seat back and forth, just one side of the switch, when moved up and down, will move the seat bottom up some.
On the vertical switch for the backrest ..........that one now controls the fwd and aft movement of the seat! But even with that, it only goes so far forward and then stops. In fact, I can't get the seat to move forward enough to get the two rear bolts back in the rail to bolt the seat down to the car again.
Strangly, it appears that the memory thing is still working and "remembering" my seat position, even though the battery was disconnected for a time.
What the hell has happened? I pulled the seat out and checked all the connections again...even took the side switch apart to make sure all wires were still attached etc and it all looks fine.
I'm completely baffled at this point. Hope someone can shed some light.
Thx,
Mark
jetrocker is offline   Reply With Quote
