Old 04-19-2013, 12:40 PM   #5
woodsman
woodsman's Avatar
what would look cool are 6- piston Cheyenne turbo calipers with 997 turbo drilled rotors (350 mm -34mm). Basically the same parts as a GT2!!!!!more swept area than a tornado All it takes is alittle adaptor piece and WAM! or you can get ( 355mm- 34mm ) rotors with an aluminum hats for $600 from a bus Radium King pointed out in another thread called , goingsuperfast.com. Brembo s big brake kits look astionishingly similar (pelican) but uses a different adapter that doesn t require the caliper to be machined...
