Auto Door Window Up Issue
On my 1997 Boxster when the windows are down, if I momentarily hit the switch for the windows to go up and release them, the drivers side goes up just fine to the top. But the passenger window will stop as soon as I release the switch.
Thinking it was an issue with the switch itself, I swapped the switches with each other and the issue still only happened on the passenger window. That tells me the switches are ok.
Any ideas on what could be causing the passenger window to not do the auto up like the drivers window? The windows behave fine otherwise.
