The AC evaporator drains from the passenger side of the car near the centerline around the gear shift area fore and aft.
On mine, when I park on a slight down slope, the water pools in the heating/AC box and drains when I back out of my space. This could also happen if one parks on a slight up slope. The condensate will drain when the car levels out.
PS: if its really isi from the front right, you likely have a leaking radiator hose or radiator. Can you tell if if coolant or water?
