Old 04-18-2013, 05:00 AM   #1
Pup
Noise Temp and RPM Specific
mornin' all,
Yes, I have used the search funtion:
I have a strange noise, howl, high pitched, hard to describe... Occurs only when temp is 180 or above and rpms are at 1800-2000 rpm. Not gear or speed dependant , that I can tell..
Doesn't occur above that rpm range. Does not occur if accellerate hard or easy thru that rpm range. Does not occur till motor has warmed up.
No leaks, drips , loss of power or any other symptoms..
Ideas?
Thanks-
Pup
1999 Boxster Base Ocean Blue Metallic 5 speed with hardtop
2015 Porsche Macan Turbo
2021 Mini Cooper S Convertible, Black Leather, 5 speed The Misses car
Pup is offline   Reply With Quote
