Old 04-16-2013, 01:58 PM   #1
LAP1DOUG
LAP1DOUG's Avatar
You may want to re-align a bit to use NT-01s. I run about -2 degrees for very even wear. Nittos don't need as much camber as RA-1s or other Rcomps. A small wheel spacer may also be in order.
Thanks for the suggestion. I tried some 7 mm spacers already but that was no help.
Everyone's comments started me thinking on what could be different, and it finally hit me - I have adjustable caster with the lower control arms that I'm using, so I should be able to back off the huge amount of caster I'm running and directly improve the tire scrub.
Thanks all
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
