Old 04-16-2013, 08:25 AM   #1
Alpine003
Thumbs up FS: Bored OEM eGas Throttle Body
I have a ported eGas throttle body for select m96 Boxster(pre 2007), all 996 Turbo, Cayenne, and Cayman models pre 2007. It has been professionally ported from the stock 68mm to slightly over 71mm with new enlarged butterfly plate as well. Maxbore has said 72mm but with my cheapo caliper, it measures between 71-72mm.
Places like FVD charges close to $400 for this service.
I bought this to use on my Carrera but found out I got the wrong model. This one has around 10k miles on it.
Please check your TB model for compatibility as you are responsible for fitment. Part # is 986 605 115 01
A stock TB is close to $1400 new from dealer or close to $600 for aftermarket Bosch unit.
No Core Required so no downtime. It should be direct bolt on and plug and play for eGas 986 boxster owners but please do your research first.
I have a Carrera so I'm mainly on the Rennlist and 6speed forums. I can also provide eBay references upon request.
SOLD
Alpine003 is offline   Reply With Quote
