Originally Posted by insite
i was reading over some chatter about a similar issue on another forum. one guy said his AF issue was solved by raising his fuel rail. he was using the boxster fuel rails w/ the 996 injectors. when he raised the rails to the right height, his AF problem went away.
this doesn't make sense to me. anyone see what i'm missing?
(FWIW, i know that the 986 & 996 injectors are identical. my personal solution was to modify the 996 rails to work on the 986, so this issue is not a concern to me).
Fuel pressure and injector setting differences in conjunction with intake airflow differences....just a thought
986 00S
