Old 04-15-2013, 11:47 AM   #6
jgama25
I have had the glass top for over a year now. I changed the MAF and also installed the air intake without any issues. Yes it's a little less access, but its not bad at all. Even with a little less access you'll get used to the diffrence quickly. The only other thing you will notice is just taking an extra step of tying the glass in order to keep it up so you can acces the engine whereas previously you didn't have to do that. Although doing it by yourself for the first time may be awkward at first because you will have to try and hold up the glass while strapping it as tight as you can to give youself as much access as possible. However, once you do it the first time, its easy the second time.
1999 black boxster
jgama25 is offline   Reply With Quote
