Thread: Window problem
Old 04-15-2013, 06:30 AM   #4
Cat
Originally Posted by Heiko View Post
Have you had the battery disconnected by any chance?
Try cycling the convertible top fully once (completely)... when that's done..
and with the roof closed, close the window and keep the switch pressed
for at least five seconds after the window closes; then open the window
and hold for an additional 5 seconds keeping the switch pressed after it gets
to the bottom. Do this for drivers and passenger windows separately ...
hopefully that should fix the problem!
H
Hi H ,
yes the battery has been disconected - i will try the resets thanks
C
Cat is offline   Reply With Quote
