2001S. Not sure if it's single or dual row. 104K miles. Original bearing. Clean oil filter at last change. Will switch to Motul and a magnetic drain plug at next oil change in 2K miles. Will replace IMSB with IMS Solution when the Solution is available in the aftermarket.
