Old 04-12-2013, 11:19 AM   #1
wawa
Second AOS in les then 2500miles. What could cause that?
Hello All
2000 Boxster S. In november I had problem with smoke on startup and sometime on had acceleration with rpm over 5000. I change the AOS and the MAF from Pelican parts. All was working good.
Now wednesday night, lots of smoke while coming home. Now lots of smoke on start up, and very hard to old idle. code P0102 related to MAF, but with all the smoke I think its the AOS again causing the code. So I just open the intake and its full of oïl as expected. So I guest the AOS is blown again.
What could cause the AOS to broke in less then 2500miles?
Later all
Chris
wawa is offline   Reply With Quote
