Old 04-12-2013, 09:21 AM   #8
tconnarn
Texas-T
tconnarn's Avatar
I found it helps if the nut at the top of the spindle and other control arm bolts are loosened a bit.
Hopes that helps. If you need to PM or call I can walk you through it. It makes no sense this has taken so long to get done. Meanwhile, you cannot have fun!
Thank you Homeboy. I agree that its taking too long! It's been driving me crazy. Every day i've made a little progress after i've gotten home from work. As soon as i get this B Joint together i should be good to go. If it comes down to it, i may loosen up the nut at the top of the control arm, but if i do that wont it require a new alignment $$?
tconnarn is offline   Reply With Quote
