Old 04-12-2013, 09:07 AM   #1
The Radium King
The Radium King's Avatar
it must be clipped/screwed in, as the rubber / plastic liner which joins the engine side of the outlet with the fender side of the outlet removes from the inside (you remove your airbox, undo a couple of bolts and pull it out). it's just a matter of locating the clips.
in reality, it don't see it as much of an impedement to airflow; it doesn't restrict the amount of air into the airbox like the snorkle does. good luck getting the snorkle off without removing it, however.
