thank you. i may try that when i reinsert the joint. yes, that happened when i was removing it. i am hoping that it doesn't get caught inside the upper lip again on the way back in. right now i am just trying to figure out how to get enough downward force on the control arm to lower it below the wheel carrier just to get it in the hole. i may chain some freeweights to it and see if that helps
