Old 04-10-2013, 07:06 PM   #1
darknight
darknight's Avatar
Originally Posted by broken2bfree View Post
Am a little confused about what tool to buy to hold cams in place. Pelican recommends a $235 camshaft securing tool. Can I just use the cam shaft lock that comes with the ims bearing puller? I have to get in and replace a chain tensioner and the last thing I need is to add to my grief by getting timing outa whack.
Are you doing the IMS bearing? I just did this on the Saturday before Easter and I used the cam lock included with the IMS bearing puller; you shouldn't need to buy an additional lock. It will include one for the five-chain motor and one for the three-chain motor. As per the instructions, you will turn the crank until the motor is at TDC, lock the crank, and you should then be able to install the appropriate cam lock on the passenger side bank.
darknight is offline   Reply With Quote
