					Originally Posted by  ccstud17
				Sam C:  great idea to check fuses. the fuse for the locks/trunks et all is.... drumroll.......in the m535 under the seat!
that is why I and others suggested you look into it.... it is 4 bolts to remove the seat! very time effective to check it out if you ask me so you wont be "chasing your tail," and you can kill 2 birds with one wrench!
I had to remove mine on the side of a street in Eugene OR, it is a pretty easy task.
and again let me suggest after drying it out and checking fuse/block for corrosion that you use silicon and di-electric grease upon re-assembly
Best of luck and keep us updated!
That's why I asked, brother... because I didn't know where the relays were. If they're under the seat, then so be it. I was just saying the immobilizer or the m535 or whatever we're calling this particular magical box designed by Porsche for the sole purpose of frunking over their customers by shutting down their cars at the most inconvenient time was probably not the problem since the car starts and drives just fine and has never gotten any moisture inside.
Of course, this one magic box is just one of many installed by the demigod like engineers (read: "retards") at Porsche to make these cars as finicky and ridiculous and failure prone as possible. Just my opinion.
Thanks for the feedback though, I'll yank the seat tomorrow and check things out.
As for the potential difficulty of removing the seat, I'm not too worried about it...
http://986forum.com/forums/general-discussions/43775-winter-mini-overhaul-complete.html
