I discovered both the idler pulleys are available at local parts stores as just a 70mm idler pulley that's used on dozens of Audi and VW products. Cost $17 each vs the $150 that I've seen elsewhere. I did have to use a washer behind them to shim them out to the run on the same plane as the belt.
I also replaced the water pump, installed a 160° thermostat, and flushed the transmission fluid.
Finally, the clutch arrived after 3 weeks and of course, it's a solid disc and not a sprung hub!! Damn it!!
