Old 04-09-2013, 08:31 PM   #21
sam c.
I'm pretty sure when I go back to do the clutch disc again in the winter, I'll probably swap in one of the ceramic bearings Homeboy found during his IMSB nightmare with LN Engineering. In the meantime tho, my stock dual row bearing came out without a hitch and was in fantastic shape.
I froze the Pelican IMS bearing and install tool overnight in the freezer, right next to the freezer vent, and then stored it in a cooler filled with dry ice for about three hours before the install. Additionally, I removed the cross member that runs behind the engine as it could be a source of potential obstruction and I wanted as clean and open an area as possible. After removing my old bearing, I installed the new one making sure to smack the install tool as straight and even as possible with a solid hammer. Installed with no issues.
sam c. is offline   Reply With Quote
