Old 04-09-2013, 09:15 PM   #11
sam c.
The list of tasks that I wanted to tackle during this mini make over is as follows:
1) ims bearing
2) clutch
3) flywheel (maybe)
4) under drive pulley and belt
5) aos
6) water pump
7) low temp thermostat
8) sparkplugs
9) transmission fluid flush
10) repair a seam on the top (or replace the top if necessary)
11) install rear speakers
12) replace passenger side inner door panel
13) check brakes for wear and replace as necessary
14) paint the brake calipers
15) fix/replace anything broken etc.
sam c. is offline   Reply With Quote
