Thread: Deep Sumps
Old 04-09-2013, 08:19 PM   #10
jaykay
jaykay's Avatar
Exclamation
Originally Posted by spendy View Post
BTDT, I also have an '06 cayman S with the older style mantis sump and backdated swirl pots. On that one I hammered depressions in the windage tray to clear the swirl pots. I think that approach may work better, since there are not extra openings in the tray, but it took a lot longer...
Wow! I think you want the swirl pot exhaust to discharge close to the oil pick up otherwise you may be starving the engine of oil this way. The windage tray will impede oil return no???
You want the tray to cover the sump, pick up and swirl pot discahrge for a segregated oil control compartment....so as a I recall you want holes for them to poke down into the segregated oil volume......I have the new version but I would have thought the arrangement would be the same for the old.
986 00S
