					Originally Posted by  spendy
				I installed the most recent design mantis sport on my 986.  Had to cut clearance holes in the windage tray for the swirl pots to clear, otherwise no worries.  It has a spacer on the pickup also.
Jeeeez that is right..Interestingly enough, I have heard of Cayman guys back- fitting to these older swirl pots as replacement for the 987 direct return type.....better de-aeration apparently.
Yup you need to cut some holes to get the pots past the tray
