Old 04-09-2013, 08:38 AM   #6
CoBeerToad
CoBeerToad's Avatar
Originally Posted by sam c. View Post
I had to take a cutoff wheel to shorten my triple square.
Thanks Porsche, you're awesome!
On the plus side, I'm probably pretty safe from thieves stealing my transmission when I run into Walmart. None of those shady SOB's carry short little triple squares around with them.
That was my thought as well!
I'm going to try and track down the Snap-On guy today after work. I'm going to see if he has an Hex style (Allen L-shaped) wrench. Hopefully he does. If not then I'll check to see if he as a 1/4" drive socket. I think either should work.
Option C will be either welding an arm onto the socket or welding some type of breaker bar that will fit into the socket and hope it don't take too much ass to break the bolt loose.
Got a Golden Tee tournament in St. Louis the weekend of the April 20th and this is my transportation. I thought I would have had plenty of time, but I don't even have the transmission out yet. Still taking my time though. Don't want to get stuck in East St. Louis.
CoBeerToad is offline   Reply With Quote
