Old 04-09-2013, 08:21 AM   #12
ccstud17
ccstud17's Avatar
my 99 did this once with the whole anti theft lock down (mine also didnt start tho)
long story short the CAS(m535) under the drivers seat had gotten a tiny amount of water from a clogged drain. If you just got it out of winter storage, id assume you washed your baby so that water could have been enough to short the system. Id recommend that you pull the seat up, pull out the m535 box take it out make sure all connections look good let it dry out or hit it with hard core Alcohol to aid in drying it, reconnect it, use silicon to seal up the box. and HOPEFULLY it works. I also advise using di-electric grease on all the connections to help keep them in tip tip shape, but i am a wee bit ocd lol
ccstud17 is offline   Reply With Quote
