Old 04-07-2013, 09:27 PM   #2
particlewave
Could've been a faulty fuel pump. The only thing that could've fried the pump motor would've been a high surge, and that is very, very unlikely. The system doesn't produce enough power to fry it. With a dc system, the pump is only going to draw as much power(amps) as it needs and the voltage will not exceed 15v.
I would check for power at the pump and go from there. My guess is that you got a bad pump...hopefully under warranty.
