Thread: loose front end
Old 04-05-2013, 03:43 PM   #5
BYprodriver
BYprodriver's Avatar
Weak struts is where I would start. How many miles on the car? Has the original ride height changed? The front nose should be level or slightly pointing down.
With that mileage your struts should be ok unless any are leaking fluid.
Try filling the gas tank full & putting some weight in the front trunk, (40-50lbs) to lower the nose slightly & see if your problem improves.
