Old 04-03-2013, 11:13 AM   #8
JFP in PA
Originally Posted by WhiteSmokeLS1 View Post
Anyone have an estimate on rebuilding one of these engines? If metal fragments went into the engine, I would assume the real expense is if you needed to bore it and replace the pistons... other than that, main and rod bearings, machine crank (maybe), rings, hone cylinders, and a gasket set doesn't seem terribly expensive. and depending on damage to the intermediate shaft... anything I'm missing?
Of course this is all assuming a worst case scenario.
There are no oversized bearings for these engines; damage the crank, throw it away. The 2.5L engine is well known for having cylinder wall issues, thinning out the walls by over boring it will not help this problem. Many rebuilders replace the OEM cylinders with CNC machined billet replacements called "nickies", which while excellent replacements, are not cheap.
Because of the way the M96 is assembled, you have two cases that split to reveal the alloy crank carrier assembly that holds the crank and rods. Because of how this goes back together, several special tools are required as just putting the retainer clips back that hold the wrist pins in place is done through a small hole, much like building a ship in a bottle.
Add in the fact that when an M96 "jumps time", a lot of really bad things can happen very quickly:
I think you need to look into what is involved a bit further...............
