Old 04-03-2013, 03:13 AM   #11
Skootnasty
You've most likely put in a new Throw Out Bearing, Have you replaced the Guide Tube?
Pelican Parts - Product Information: 996-116-087-01-M100
JFP would be the member I'd contact / PM if it were me.
+1
If the piston is pushing against the outer seal of the housing, then it is not traveling at the correct angle to the clutch arm.
Any wear on the tube for the release bearing will change the how the arm and piston move together, and if enough wear has occured (like from being used with a cracked/failed arm) then it could absolutely cause your issue.
Ufortunately, if you replaced the clutch arm before, you know what it takes to replace the release bearing guide tube.
Skoot
Skootnasty is offline   Reply With Quote
