Nothing against you or your vehicle ccstud17, but here's a clear example of why I caution others about placing too much emphasis and hype on polyurethane when it comes to aftermarket aero parts and body kits. It's a great material when all things are perfect. However, when they're not you're SOL, because poly can't be manipulated to fit like a composite material can be. And, for all that it's faulted for, fiberglass can be shaped and tweaked in every way possible in order to create the perfect fit.
