Old 04-02-2013, 05:04 PM   #1
Thanassis
Could it be the reservoir hoses?
I am following the instructions to replace the reservoir -- thank you for the nice work -- and after removing the carpeting I noticed that most coolant is accumulated under the hoses by the wall feed through plate. Is it possible that the hoses might be the problem?
I do not have the heavy accumulation of coolant as shown in the picture but coolant is spread half way through the trunk with most under the wall feed through plate.
Should I still proceed to remove the tank? Any advise would be appreciated.
Thanassis
Thanassis is offline   Reply With Quote
