With your Durametric, monitor engine rpm while cranking. It should read over 125 rpms while cranking. If it does, you need to verify coils are sparking, adequate fuel pressure, and pulse at the injectors if you get that far.
If you do not get rpm above zero, you need to inspect crank sensor and the unlikely reluctor tabs (there will be nothing wrong with these).
Skoot
