Thread: Newbie wheel Q
Old 04-01-2013, 04:21 PM   #5
Johnny Danger
Johnny Danger's Avatar
Typically, 996 wheels are not only wider, but the offset is much higher than those of the 986. The simplest way to explain offset - is the distance in millimeters between the centerline of the wheel and the back pad that interfaces with the hub. The higher the offset, the more the wheel will be positioned inward toward the strut. The lower the offset, the more the wheel will extend outward toward the fender. With the exception of an 11 inch wheel, most 996 wheels can be augmented to fit a 986 with the proper use of spacers.
